Введение
This guide gives step-by-step instructions to replace the XtraVision Fog Light/Headlight Bulb 9005XV-2 in a 2017 Kia Niro. Fog Light/Headlight bulb usually burns out after 1000 hours and it needs to be replaced but some others last for 30000 hours. When replacing Fog Light/Headlight Bulb 9005XV-2 in a 2017 Kia Niro, Fog Light/Headlight Bulb should be changed in pairs. For safety concerns, Bulbs should be changed before they burned out because driving without functioning bulbs can be dangerous at night.
Инструменты
Инструменты не указаны.
Запчасти
Open the hood of the vehicle and make sure it is secured to prevent injury.
Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
Place the cap in a location that is out of the way of your work area and where you can easily find it.
Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
Insert the new bulb by pushing it into the bulb compartment.
Turn the bulb clockwise until it is secure.
