Введение
You will need basic hand tools and a spring clip remover. Adding an aftermarket pipe is easy. You can do it.
Take off the rear rack and the seat. Remove top cover, left side panel, floor board, and rear fender.
Unhook retaining spring, unbolt hanger, and the pipe should slide off with minimal effort. (the springs are strong)
Slip new pipe on, reinstall retainer springs. Bolt hanger to frame. (no modifications necessary)
