2018 Dodge Charger Headlight Bulb Replacement
Выберете то, что вам нужно
  1. 2018 Dodge Charger Headlight Bulb Replacement, Prerequisites: шаг 1, изображение 1 из 1
    • Before you begin, make sure the vehicle is turned off and placed in park with the parking brake engaged.
  2. 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: шаг 2, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: шаг 2, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: шаг 2, изображение 3 из 3
    • Open the hood by pulling the release lever inside the vehicle, located on the driver's side by the parking brake.
    • Once pulled, you will hear the sound of the hood pop open.
  3. 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: шаг 3, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: шаг 3, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: шаг 3, изображение 3 из 3
    • Carefully place your hands under the hood, towards the middle of the car.
    • When you feel the lever, push it to the left using your left hand and slowly push the hood up with your right hand.
    • If your Charger has or requires a stand, prop it up.
    • This model of Charger does not require a stand to hold the hood. It will automatically hold on its own.
  4. 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: шаг 4, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: шаг 4, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: шаг 4, изображение 3 из 3
    • On the passenger side of the car, unscrew the cap covering the headlight compartment.
    • Remove the cap from the headlight.
    • Use gloves to protect your hands.
  5. 2018 Dodge Charger Headlight Bulb Replacement, Remove the old bulb: шаг 5, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Remove the old bulb: шаг 5, изображение 2 из 2
    • Once you remove the cap, you will see the current bulb that is installed.
    • Slowly twist the bulb clockwise, and remove it from the compartment.
  6. 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: шаг 6, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: шаг 6, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: шаг 6, изображение 3 из 3
    • Unplug the bulb from the adapter.
    • Lift the lever and carefully detach it.
    • Place the bulb in a safe area away from the vehicle.
  7. 2018 Dodge Charger Headlight Bulb Replacement, Reconnect a new bulb to the adapter: шаг 7, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Reconnect a new bulb to the adapter: шаг 7, изображение 2 из 2
    • Connect a new light bulb to the adapter.
  8. 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: шаг 8, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: шаг 8, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: шаг 8, изображение 3 из 3
    • Align the bulb to the shape of the hole and turn clockwise to safely lock.
    • After installation, you will see cables sticking out. You can manage this by fitting it in the compartment.
    • Place the cap back on the compartment and tightly seal it.
  9. 2018 Dodge Charger Headlight Bulb Replacement, Accessing the driver's side bulb: шаг 9, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Accessing the driver's side bulb: шаг 9, изображение 2 из 2
    • To access the driver's side lightbulb, you have to remove the air intake from under the hood.
  10. 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: шаг 10, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: шаг 10, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: шаг 10, изображение 3 из 3
    • Loosen two bolts using a 1/4 ratchet with a 5/16 inch socket.
    • Gently loosen the bolt. Loosening it too quickly may result in the screw falling into the engine compartment.
  11. 2018 Dodge Charger Headlight Bulb Replacement, Remove the bolts manually: шаг 11, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Remove the bolts manually: шаг 11, изображение 2 из 2
    • Once the screw is loosened, use your hand to continue the process.
  12. 2018 Dodge Charger Headlight Bulb Replacement, Detach the intake tube: шаг 12, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Detach the intake tube: шаг 12, изображение 2 из 2
    • Loosen the screw attached to the ring.
    • Detach the tube from the intake.
    • Do not remove the ring from the tube.
  13. 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: шаг 13, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: шаг 13, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: шаг 13, изображение 3 из 3
    • Grab the intake with both hands and gently lift upwards.
    • Place the intake safely on top of the main engine block.
  14. 2018 Dodge Charger Headlight Bulb Replacement, Find the headlight compartment: шаг 14, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Find the headlight compartment: шаг 14, изображение 2 из 2
    • Once the intake is safely removed, you can access the headlight compartment.
  15. 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: шаг 15, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: шаг 15, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: шаг 15, изображение 3 из 3
    • Remove the light bulb by lifting on the small lever.
    • Connect the new headlight bulb and firmly align the bulb to the compartment.
    • Double check that the bulb is properly installed and connected. If it is not installed properly, you will have to remove the intake again.
  16. 2018 Dodge Charger Headlight Bulb Replacement, Realign the air intake: шаг 16, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Realign the air intake: шаг 16, изображение 2 из 2
    • Place the intake back in its original place.
    • Align the bottom of the intake to its original spot as seen in the picture.
  17. 2018 Dodge Charger Headlight Bulb Replacement, Tighten the intake screw: шаг 17, изображение 1 из 2 2018 Dodge Charger Headlight Bulb Replacement, Tighten the intake screw: шаг 17, изображение 2 из 2
    • Place the bolt and ring back on the intake.
    • Tighten the screw with your hands and finish securing the screw using the 1/4 ratchet and the 5/16 in socket.
  18. 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: шаг 18, изображение 1 из 3 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: шаг 18, изображение 2 из 3 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: шаг 18, изображение 3 из 3
    • Firmly attach the tube to the intake.
    • Tighten the screw using the 1/4 ratchet with the 5/16 inch socket.
    • Close the hood of the vehicle.
    • Before closing the hood, make sure the engine compartment is clear of obstruction.
  19. 2018 Dodge Charger Headlight Bulb Replacement, Test the new lightbulbs: шаг 19, изображение 1 из 1
    • Power on the vehicle to ensure the new headlight bulbs are successfully working.
Заключение
Congratulations, you've successfully replaced both lightbulbs!
Еще один человек закончил это руководство.
Anthony Does Repairs
Участник с: 03/14/22
313 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 6-18, Briggs Spring 2022 Участник CSU Los Angeles, Team 6-18, Briggs Spring 2022
CSULA-BRIGGS-S22S6G18
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 9
За последние 7 дней: 71
За последние 30 дней: 373
За всё время: 13,702
