Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a 1/4 inch flex head ratchet and a 1/4 inch shallow 10mm socket, loosen the battery cable tightening nut.
Remove the vacuum line from the front of the intake by gently pulling up on the line releasing it from the clamps.
Using a 1/4 inch 7mm deep socket and 1/4 inch flex head wrench, loosen the worm clamp on the cold air intercooler pipe.
Using a 1/4 inch 10mm wobbly socket, 1/4 inch 8 inch extension, and 1/4 inch ratchet, remove all 5 of the cap screws holding the intake to the cylinder head.
Remove the intake out of the engine bay by lifting and pulling the intake towards you.
Unplug both left and right engine ground strap connections.
Using a 1/4 inch 8mm deep socket, remove the 8 PCV plate mounting bolts.
Wipe down the mounting surface and the inside of the PCV plate with a shop rag.
Reinstall the PCV plate on the side of the engine block.
Torque the PCV plate mounting bolts to 89 inch pounds.
4 участников успешно повторили данное руководство.
