Введение
This guide will cover how to replace the windshield wipers in a 2019 Chevrolet Colorado.
The guide covers how to take off the windshield wipers as well as how to reinstall the wipers. This is a truck so some may need to use a step stool in order to reach the wipers depending on how high your truck is raised.
This is a fairly easy task that only requires your hands to disassemble and reassemble.
Before you start this guide make sure your truck is off, parked, and on a flat surface just to ensure that you are completing this guide in a safe manner.
Выберете то, что вам нужно
Disconnect the blade on the driver side by pushing the small button down in order to release the wiper.
Slowly slide the wiper off of the wiper arm by pulling it back and away from the windshield.
The wiper arm is like a hook so make sure that you completely unhook the metal piece from the wiper blade.
Grab the 22" wiper blade and position it on the wiper arm so that it is hooked into places as well as flush with the arm.
Pull the wiper blade down with your right hand and slowly push with your left onto the wiper arm until you hear it snap back into place.
Repeat steps 6 and 7 on the passenger side wiper. Make sure you are using the 18" wiper for the passenger side replacement.
to reassemble your device, follow these instructions in reverse order
