Введение
This guide demonstrates step-by-step on how to change your tail lights. It is a relatively easy process and with this alone, you can change the actual tail lights themselves and any light within the taillight.
Выберете то, что вам нужно
Open the tailgate.
Remove the top and bottom T15 screws from each side of the tail lights.
Gently remove the tail lights by pulling outward.
Plug the brake lights connector.
Twist and secure the socket tightly.
Plug in the turn signal bulb connector. Twist and secure tightly.
Plug in the parking lights connector. Twist and secure the socket tightly.
Plug in the TURN SIGNALS connector. Please follow the same steps for the other side of the tail lights.
Make sure all the connections are plugged and tight. Also ensure that the caps are sealed.
First, remove the reverse light bulb from the vehicle.
Then, connect the socket to the reverse light connector from the new tail light.
Еще один человек закончил это руководство.
