2021 Hyundai Elantra Cabin Air Filter Replacement
Выберете то, что вам нужно
  1. 2021 Hyundai Elantra Cabin Air Filter Replacement, Cabin Air Filter: шаг 1, изображение 1 из 1
    • Locate your cabin air filter. For the Hyundai Elantra 2021, it is located behind the glove compartment.
  2. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 2, изображение 1 из 3 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 2, изображение 2 из 3 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 2, изображение 3 из 3
    • Open your glove compartment.
    • Remove your glove compartment from its seat by pushing the sides of it inwards.
    • Doing so will reveal a rubber holder, which must be dislodged in order to fully remove your glove compartment.
    • Directly behind your glove compartment, you should find the cabin air filter compartment.
  3. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 3, изображение 1 из 1
    • Remove the cover protecting your cabin air filter.
    • Pinch the right side of the cover in order to dislodge it, and pull the cover off.
  4. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 4, изображение 1 из 1
    • Remove the filter by pulling it out of the compartment.
  5. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 5, изображение 1 из 2 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 5, изображение 2 из 2
    • To install the new cabin air filter, simply insert it into the compartment where you took out the old filter.
    • Make sure you install the air filter with the correct orientation (air flow arrow pointing downwards). If your air filter's orientation is incorrect, your car's A/C will not filter the air properly.
  6. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 6, изображение 1 из 1
    • Reinstall your cabin air filter cover by tucking the left side in first, then pinching the right end of it to place it back in it's compartment securely.
    • You may want to dust off your cabin air filter cover to eliminate excess dust.
  7. 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 7, изображение 1 из 2 2021 Hyundai Elantra Cabin Air Filter Replacement: шаг 7, изображение 2 из 2
    • Reinsert your glove compartment by pinching the ends of it together, in order to fit the rubber holders in their respective holes.
    • Align the back hooks of the glove compartment and secure them.
Заключение
By the end of this guide, you should have been able to replace your Hyundai Elantra 2021 cabin air filter properly. Enjoy clean, fresh air!
3 участников успешно повторили данное руководство.
Omar Mosly
Участник с: 09/20/21
193 Репутация
1 руководство автора
Команда
York University, Team E-18, Melo-Thaiss Fall 2021 Участник York University, Team E-18, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG18
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 23
За последние 30 дней: 119
За всё время: 7,837
