360fly 4K SD Card Replacement
Выберете то, что вам нужно
  1. 360fly 4K SD Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K SD Card Replacement: шаг 2, изображение 1 из 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K SD Card Replacement: шаг 3, изображение 1 из 2 360fly 4K SD Card Replacement: шаг 3, изображение 2 из 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K SD Card Replacement: шаг 4, изображение 1 из 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K SD Card Replacement: шаг 5, изображение 1 из 2 360fly 4K SD Card Replacement: шаг 5, изображение 2 из 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K SD Card Replacement: шаг 6, изображение 1 из 3 360fly 4K SD Card Replacement: шаг 6, изображение 2 из 3 360fly 4K SD Card Replacement: шаг 6, изображение 3 из 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K SD Card Replacement, SD Card: шаг 7, изображение 1 из 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K SD Card Replacement: шаг 8, изображение 1 из 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K SD Card Replacement: шаг 9, изображение 1 из 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K SD Card Replacement: шаг 10, изображение 1 из 1
    • Press and release the SD card to remove it from the circuit assembly.
Заключение
5 участников успешно повторили данное руководство.
Jacob Herron
Участник с: 11/08/17
463 Репутация
Автор 3 руководств
Команда
IUPUI, Team S5-G3, Baechle Fall 2017 Участник IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 членов
Автор 3 руководств
Один комментарий
Really useful guide, thanks
John Erikson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 22
За всё время: 1,095
