Введение
If your device is failing to charge or if your device loses charge quickly, it may be time to replace the battery. This guide will show you how to replace the battery in your 3DR Iris Plus Quadcopter.
Note: At the time of guide creation, the device did not come equipped with a battery.
Power off the drone by holding down the power button.
Remove the battery by disconnecting it from the main battery connector.
Press the power button again to ensure all electricity is discharged.
Почти готово!
Финишная черта
