Введение
This guide shows how to remove the legs on the bottom of the drone.
Выберете то, что вам нужно
Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
Locate the rubber grip at the end of the leg and, with your thumb, peel it back and pull it off.
Gently pull up on and remove the plastic covering labeled "solo antenna".
Locate the antenna wire and carefully pull up and remove it.
