3rd party DualShock 2 Wireless Controller Analog Stick Replacement
Выберете то, что вам нужно
  1. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: шаг 1, изображение 1 из 2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: шаг 1, изображение 2 из 2
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
  2. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 2, изображение 1 из 2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 2, изображение 2 из 2
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
  3. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 3, изображение 1 из 2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 3, изображение 2 из 2
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
  4. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 4, изображение 1 из 2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 4, изображение 2 из 2
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
  5. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: шаг 5, изображение 1 из 1
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
Заключение
22 человек успешно провели ремонт по этому руководству.
Roger Campbell
Участник с: 07/12/17
377 Репутация
1 руководство автора
Команда
Texas Tech, Team S1-G1, Rauch Summer 2017 Участник Texas Tech, Team S1-G1, Rauch Summer 2017
TTU-RAUCH-SU17S1G1
2 членов
Автор 4 руководств
1 Комментарий к руководству
The controller featured here is not an official Dualshock 2 controller.
Synapse - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 17
За последние 7 дней: 82
За последние 30 дней: 305
За всё время: 17,596
