Введение
In a gasoline engine, a Spark Plug provides an electrical spark to ignite to fuel inside, generating horsepower. Over time, a Spark Plug's ability to ignite will reduce from wear and eventually not work. Replacing Spark Plugs ensures your engine will run at optimal efficiency.
Выберете то, что вам нужно
Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
Remove the Champion RC12YC Spark Plug from the device.
2 участников успешно повторили данное руководство.
