Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Hold the controller with its back facing towards you.
Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
Place the controller face down on a solid surface.
Remove the seven screws with the Phillips #00 screwdriver.
Lift the body of the controller up and away from the controller's face and buttons.
Lift away the black rubber pads that sit between the face buttons and body of the controller.
Align the notches of the face buttons to put them back into place.
Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
Еще один человек закончил это руководство.
2 Комментариев
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
