Введение
This guide will show you in detail how to remove the AARP RealPad. In order to remove the back cover you will need to know how to use a screwdriver and a suction cup.
Выберете то, что вам нужно
Loosen the back cover using the suction cup.
Pull up on the center of the back with the suction cup.
Pull up on all four corners of the back with the suction cup.
Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
Slide the opening tool around the edges of the device.
Wedge it open using the opening tool.
Еще один человек закончил это руководство.
