Введение
If your laptop is currently experiencing full memory then this guide below will show you step by step how to replace the ACER Aspire 7750G 6645 Hard Drive. Once the new Hard Drive is installed the memory of the laptop will be empty.
Выберете то, что вам нужно
Remove three 60mm Phillips #00 screws that are holding the bottom cover in place.
Remove two 4mm Phillips #00 screws that are holding the hard drive in place.
Push the hard drive to the right and push it upward to remove. You may need a spudger or plastic opening tool to assist you with this step.
Еще один человек закончил это руководство.
