Введение
Using this guide will allow you to replace your hard drive.
Выберете то, что вам нужно
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Slide the lock switch to the right using your finger or a spudger.
At the same time, grasp the battery with your other hand and slide it out of the laptop.
Remove the battery.
Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
5 участников успешно повторили данное руководство.
