Введение
This guide will show you how to properly remove and replace the battery from the AEE Mach 1 drone. It is important to first power off the device before beginning any repairs. Disassembly and replacement will not require any additional tools or skills. The process simply involves orienting the drone camera away from you, pressing the battery retainment tabs and pulling, followed by reinserting the new battery until hearing the tabs click.
The battery is located at the back of the drone, on the opposite end of the drone from the camera.
There are two tabs on the edge of each side of the battery.
To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
Еще один человек закончил это руководство.
2 Комментариев
purchase the aee mach 1 but it has no battery
How do I get a new battery where do I look
