Введение
The speaker can sometimes stop working and must be replaced to continue to hear noise from the tablet.
Выберете то, что вам нужно
Remove screws.
Insert spudger tool on the middle of the left side, between the white and black plastic.
Slide in a plastic opening tool and use it to further pull the back off.
Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
Pull off the back cover.
Locate the speaker solder points and note where it is attached to the motherboard.
Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
Replace the back cover with the new rear speaker unit in place.
Gently press the speaker into place.
Replace the screws.
