Введение
This guide will take you through a step-by-step process for the removal of your Chromebook’s speakers.
Выберете то, что вам нужно
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
Disconnect the speaker's black bundled cable connector on the motherboard.
Pinch the black bundled cable connector between your thumb and pointer finger and pull.
Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
Flip the ZIF retaining flap up using a spudger or your fingers.
Pull gently on the ribbon cable to remove it from the connector.
Using the small plastic opening tool, pry the left speaker from the Chromebook.
Remove the speakers.
