Введение
This guide will take you through a step-by-step process for the removal of your Chromebook’s touch pad.
Выберете то, что вам нужно
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
Disconnect the touch pad ZIF(zero insertion force) connector.
Flip the flap up using a spudger or your fingers.
Pull gently on the ribbon cable to disconnect.
