ASUS D550MA-DS01 CMOS Battery Replacement
Выберете то, что вам нужно
  1. ASUS D550MA-DS01 CMOS Battery Replacement, Keyboard Module: шаг 1, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement, Keyboard Module: шаг 1, изображение 2 из 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
  2. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 2, изображение 1 из 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 3, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement: шаг 3, изображение 2 из 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
  4. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 4, изображение 1 из 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  5. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the fully disconnected keyboard module from the laptop.
  6. ASUS D550MA-DS01 CMOS Battery Replacement, Battery: шаг 6, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement, Battery: шаг 6, изображение 2 из 2
    • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
    • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
  7. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 7, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement: шаг 7, изображение 2 из 2
    • Lift the battery out and remove it:
    • The battery is connected to the motherboard on the left side.
    • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
    • Pull straight up to lift the battery out of its place.
    • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
  8. ASUS D550MA-DS01 CMOS Battery Replacement, Hard Drive: шаг 8, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement, Hard Drive: шаг 8, изображение 2 из 2
    • Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
    • There are two screws connected to the motherboard and two screws connected directly to the case.
  9. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 9, изображение 1 из 1
    • Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
    • Be sure to fully disconnect the hard drive from the motherboard to ensure that you do not damage the connectors.
    • If necessary, unscrew the old hard drive from the holster and screw the new one into the holster.
  10. ASUS D550MA-DS01 CMOS Battery Replacement, DVD Drive: шаг 10, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement, DVD Drive: шаг 10, изображение 2 из 2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
  11. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 11, изображение 1 из 1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
  12. ASUS D550MA-DS01 CMOS Battery Replacement, Motherboard: шаг 12, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement, Motherboard: шаг 12, изображение 2 из 2
    • Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
    • While unscrewing the screws, it may be helpful to use the tweezers to keep control of the screws.
  13. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 13, изображение 1 из 3 ASUS D550MA-DS01 CMOS Battery Replacement: шаг 13, изображение 2 из 3 ASUS D550MA-DS01 CMOS Battery Replacement: шаг 13, изображение 3 из 3
    • Disconnect the three cables attached to the motherboard.
    • Do not pull the cables by their wires. This can lead to damage to the cables.
    • The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
    • There may be clear tape holding the screen connector in place.
    • The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
  14. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 14, изображение 1 из 1
    • Pull the motherboard to the right to clear the peripheral connections of the laptop casing.
    • Lift the motherboard out of the laptop.
  15. ASUS D550MA-DS01 CMOS Battery Replacement, CMOS Battery: шаг 15, изображение 1 из 1
    • Locate the CMOS battery on the reverse side of the motherboard.
  16. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 16, изображение 1 из 2 ASUS D550MA-DS01 CMOS Battery Replacement: шаг 16, изображение 2 из 2
    • Place the narrow end of the black spudger in the small recess between the battery and its housing.
    • Gently slide in the spudger and pry the battery out.
    • The battery should spring out of the housing.
  17. ASUS D550MA-DS01 CMOS Battery Replacement: шаг 17, изображение 1 из 1
    • Lift the battery out of the housing.
Заключение
redacted
Участник с: 09/15/15
543 Репутация
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 29
За последние 30 дней: 61
За всё время: 3,657
