Введение
The Power Buttons serves as the primary interface to boot up your computer. This guide will give you a step-by-step procedure on how to replace your Power Button in the case that it goes bad.
Выберете то, что вам нужно
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
Lay the keyboard with the key-side down. The circuit for the Power Button is just beneath the location of the button.
Unscrew the 2 screws holding the circuit in place, using the Philips #1 Screwdriver.
Lift upward and remove the circuit board for the Power Button from the Keyboard Module.
