Введение
This guide will teach you how to properly take apart your Asus to replace the track pad.
Выберете то, что вам нужно
Flip the laptop over and locate the battery lock tabs.
Slide the right tab to the unlock position (right) so that a red dot is showing. Then, slide and hold the left tab to its unlock position (left).
Pull the battery out.
Remove the four 4.76 mm screws using the Phillips J0 screwdriver.
Lift up on the hard drive cover to remove.
Starting from the left, use a plastic opening tool to slide the hard drive all the way to the right.
Once the hard drive is all the way to the right, lift it up on the hard drive and pull it out.
Remove the 4.76 mm screw under the hard drive using the Phillips J0 screwdriver.
Flip the laptop back over and unlock the three keyboard tabs at the top of the keyboard by pushing down on the silver tabs with tweezers .
Using a pair of tweezers, disconnect the cable at the bottom of the keyboard by flipping the two black lock switches up on both sides of the cable.
Remove the nine 4.76 mm screws from the surface of the laptop using the Phillips J0 screwdriver.
Using a pair of tweezers, unlock the blue touch pad ribbon by pushing the white lock tab to the right.
Using a plastic opening tool, remove the cover of the laptop by prying up the edges.
Lift up and remove the top cover of the laptop.
Flip this cover over to reveal the back.
Using the plastic opening tool, gently pry the metal foil up around the edges of the trackpad.
Lift the metal plate up to expose the trackpad.
Now you can safely remove the track pad.
