ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement
Выберете то, что вам нужно
  1. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Back Panel: шаг 1, изображение 1 из 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Back Panel: шаг 1, изображение 2 из 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 2, изображение 1 из 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 2, изображение 2 из 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 2, изображение 3 из 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 3, изображение 1 из 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 4, изображение 1 из 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 5, изображение 1 из 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 6, изображение 1 из 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: шаг 6, изображение 2 из 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove screws: шаг 7, изображение 1 из 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws found on back side of the device to the left of the rear-facing camera.
  8. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Lift up flaps: шаг 8, изображение 1 из 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Lift up flaps: шаг 8, изображение 2 из 2
    • Use Plastic Opening Tool to lift up the two white flaps.
  9. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove wire clip: шаг 9, изображение 1 из 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove wire clip: шаг 9, изображение 2 из 2
    • Use Tweezers to unclip the wire from the back panel by pulling straight outward from the device.
  10. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: шаг 10, изображение 1 из 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: шаг 10, изображение 2 из 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: шаг 10, изображение 3 из 3
    • Pull microSD Card, HDMI Port, and Headphone Jack panel straight out from tablet.
    • Use Plastic Opening Tool to remove the wire on the panel by hooking it around the white clip and pulling straight out from the panel.
Заключение
4 участников успешно повторили данное руководство.
Sandy Babich
Участник с: 09/23/14
1 847 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 13-9, Forte Fall 2014 Участник Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 3,853
