Введение
This guide will explain the process of installing more RAM, or replacing pre-existing RAM. The ASUS F555UA-EH71 includes 4gb of RAM soldered to the motherboard, along with a slot for additional memory located in the bottom of the device.
Выберете то, что вам нужно
Flip the laptop over to access the bottom side of the device. Remove the black Phillips #0 screw that holds the RAM access panel in place.
Gently lift up on the side of the panel to remove it.
Еще один человек закончил это руководство.
