Запчасти
Никакие детали не требуются.
  1. With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver. With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver. With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Carefully pry the panel away from the computer, by lifting with a finger. There is a small tab where a finger will fit to lift the panel away from the computer. There is a small tab where a finger will fit to lift the panel away from the computer.
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
Заключение
Deven Rodgers
Участник с: 23.10.2018
253 Репутация
Автор 3 руководств
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 47
