Введение
If you suspect your ASUS G73JH-BST7, or ASUS G73 Gaming Series Laptop, is malfunctioning because of hardware issues, you will need to remove the back panel to investigate.
Make sure to power down your device before you begin.
Выберете то, что вам нужно
With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
Carefully pry the panel away from the computer, by lifting with a finger.
There is a small tab where a finger will fit to lift the panel away from the computer.
