ASUS GL752VW-DH74 Optical Drive Replacement
Выберете то, что вам нужно
  1. ASUS GL752VW-DH74 Optical Drive Replacement, Optical Drive: шаг 1, изображение 1 из 1
    • Begin by putting the needle into the hole in the disk tray.
    I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
    Stephen Patterson - Ответить
  2. ASUS GL752VW-DH74 Optical Drive Replacement: шаг 2, изображение 1 из 1
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Optical Drive Replacement: шаг 3, изображение 1 из 1
    • Pull out disk tray entirely.
    I was not able to extract the DVD drive until unscrewing the .8 screw central on the back of the laptop. That one holds the DVD drive.
    Vio Belc - Ответить
    You have to also remove the screw securing the DVD drive to the case.
    sgust - Ответить
Заключение
Ralph Lopez
Участник с: 10/23/17
202 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 Участник UMass Dartmouth, Team S1-G3, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G3
3 членов
Автор 5 руководств
Один комментарий
Prior to step 1 , there is a screw that needs removed [Middle screw on the back on the side with the DVD player]
William Irons - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,288
