Введение
This guide will show you how to remove the back panel of an Asus K200MA laptop.
Запчасти
Детали не указаны.
  1. With the opening facing you, flip the laptop over and remove the following screws from the back panel: Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath. Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. Remove the following screws:
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate. You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot. You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
Заключение
Haleigh St. Paul
Участник с: 17.09.2018
239 Репутация
1 руководство автора
Команда
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Участник CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 121
