Введение
Battery replacements for a Asus K200MA 11.6" laptop can be done easily with this step-by-step guide. Compatible with A31N1302 laptop battery.
Запчасти
Детали не указаны.
  1. With the opening facing you, flip the laptop over and remove the following screws from the back panel: Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath. Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. Remove the following screws:
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate. You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot. You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out. Gently pull the narrow connector away from the keyboard.
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges. Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. Flip the computer over so that the side with the motherboard (large green piece) is laying face-up. Remove the following screws from the middle and far ends of the battery:
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. Gripping the wider left section, lift the battery up and away from computer. Gripping the wider left section, lift the battery up and away from computer. Gripping the wider left section, lift the battery up and away from computer.
    • Gripping the wider left section, lift the battery up and away from computer.
Заключение
Aliyah Malapit
Участник с: 26.09.2018
199 Репутация
Автор 2 руководств
Команда
CSU Fullerton, Team S2-G5, Bruce Fall 2018 Участник CSU Fullerton, Team S2-G5, Bruce Fall 2018
CSUF-BRUCE-F18S2G5
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 231
