Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
With the opening facing you, flip the laptop over and remove the following screws from the back panel:
Six 4mm Phillips screws using a Phillips #0 screwdriver.
One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
Remove the following screws:
Two 4mm Phillips screws using a Phillips #0 screwdriver.
Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
Gently pull the narrow connector away from the keyboard.
Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
