Введение
This guide will tell you how to replace your hard drive, by opening up the bottom of the laptop. It is relatively simple, and only requires a screwdriver. Before doing this, you should back up all your information stored on the laptop.
Выберете то, что вам нужно
Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
Slide the back panel towards you until it stops.
Lift the panel up out of the laptop casing.
Disconnect the hard drive from the laptop by sliding it towards the outside edge.
