Введение
This guide will tell you how to open up your laptop and replace your RAM. It is relatively simple and only requires a screwdriver.
Выберете то, что вам нужно
Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
Slide the back panel backwards until it stops.
You can now lift the panel up and out of the laptop casing.
The RAM is now visible.
Remove the RAM by pressing out on both tabs visible on each side of the RAM.
To work the tabs, take your finger tips and press outwards from the indents on the RAM.
The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
Gently Pull the RAM out of its connector without pushing down or pulling up.
