Введение
If your speakers on ASUS Memo Pad FHD tablet isn't working properly, then you can use this guide to replace the speakers.
Выберете то, что вам нужно
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
