Введение
This guide will detail how to remove and replace the back case of the device. This will give you access to the inner parts of the laptop.
Выберете то, что вам нужно
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
4 участников успешно повторили данное руководство.
