Введение
The removal of the battery is an essential bit of knowledge, since you will have to do this before most other repairs. Removing the battery first creates a safe environment to work in, which will eliminate most shock hazards.
Выберете то, что вам нужно
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
4 участников успешно повторили данное руководство.
