Введение
This guide will show you how to remove and replace the laptop's CD/DVD Drive. This may be necessary if your drive suffers some sort of hardware failure such as not ejecting or the inability for it to read disks.
Выберете то, что вам нужно
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
Remove the two 4mm black Phillips #1 screws from the top of the CD/DVD bracket.
Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
Remove the CD/DVD bracket.
2 участников успешно повторили данное руководство.
