Введение
This guide will show you how to replace the screen on a Asus N550JK-DS71T laptop.
Выберете то, что вам нужно
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
Remove the eight black 4mm Phillips #1 screws holding display to laptop base.
Open then close the laptop to separate the metal hinges between display and base.
Open the laptop again then gently remove the base of the laptop from the display.
Remove the two 4mm black Phillips #0 screws from the bottom of the display.
Slide the screen to the bottom of the display to disengage the mounting clips.
Using a spudger or soft pry tool, work your way around the edge of the screen to separate the screen from the bezel adhesive strips. Take your time, and be careful not to break the bezel.
Before installing new screen, ensure that the adhesive strips are laying flat around the edges, and clean the surface of the screen of debris from prying the old screen off. These will show up on the new screen if you sandwich them in between the glass and the screen.
8 участников успешно повторили данное руководство.
2 Комментариев
What is the screen model? I need it to buy a separate controller to use the laptop screen as an external monitor
