Введение
Whether your hard drive died, you need more space, or need faster speeds, this guide will show you how to replace the hard drive in your ASUS N56JN Laptop.
Выберете то, что вам нужно
Pull the switch on the back of laptop in the direction of the arrow.
If done correctly the battery should pop out. Lift the battery to remove it.
Remove the screw that was uncovered.
Pull the backing plate away from the laptop.
Push the hard drive away from the center until fully disconnected.
Lift the hard drive from the bottom right tab to remove it from the laptop.
To reassemble your device, follow instructions 1-6 in the reverse order.
8 участников успешно повторили данное руководство.
2 Комментариев
That’s not rocket science - How to clone the disk properly? that’s the part I can’t manage… Any freeware clone software that actually WORKS and is not just a dumb backup software…?
The free version of Minitool Partition Wizard is very good.
