ASUS PadFone X Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: шаг 1, изображение 1 из 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: шаг 1, изображение 2 из 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: шаг 2, изображение 1 из 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: шаг 2, изображение 2 из 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: шаг 2, изображение 3 из 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: шаг 3, изображение 1 из 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: шаг 3, изображение 2 из 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: шаг 4, изображение 1 из 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: шаг 5, изображение 1 из 1
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: шаг 6, изображение 1 из 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
Заключение
nestor
Участник с: 10/07/14
101 Репутация
1 руководство автора
Команда
USF Tampa, Team 8-4, Leahy Fall 2014 Участник USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 519
