ASUS PadFone X Station Power and Volume Contacts Replacement
Выберете то, что вам нужно
  1. ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: шаг 1, изображение 1 из 2 ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Power and Volume Contacts Replacement, Locate CON1501: шаг 2, изображение 1 из 1
    • Locate CON1501
    • CON1501 will be visible underneath the contacts. You can readily see this if you look for the orange strip of film in the top right corner of the back of the Asus Padfone X Docking Station.
  3. ASUS PadFone X Station Power and Volume Contacts Replacement, Remove (1) phillips screw.: шаг 3, изображение 1 из 1
    • Remove (1) phillips screw
    • Using a +PH00 Phillips screwdriver , you will unscrew the Phillips screw in the top right corner of the back of the ASUS Padfone X docking station.
    • To unscrew the Phillips screw simply position the screwdriver inside of the screw, then rotate it counter-clockwise until the screw is fully removed from the docking station.
  4. ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: шаг 4, изображение 1 из 2 ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: шаг 4, изображение 2 из 2
    • Disconnect ribbon from CON1510
    • To disconnect the ribbon from CON1510, use a pair of tweezers and gently lift the connect up and back from the device.
  5. ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: шаг 5, изображение 1 из 3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: шаг 5, изображение 2 из 3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: шаг 5, изображение 3 из 3
    • Now that the contacts are no longer attached, you can use either tweezers or your fingers to grasp and lift contacts vertically off of the device.
Заключение
2 участников успешно повторили данное руководство.
Jessica
Участник с: 10/07/14
150 Репутация
1 руководство автора
Команда
USF Tampa, Team 7-4, Leahy Fall 2014 Участник USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 525
