Введение
Here, the back cover will be removed followed by the secondary back panel. Once this is completed and the motherboard is visible, the vibration motor is accessible and can be replaced.
Запчасти
Никакие детали не требуются.
  1. Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards. Work your way around the phone until the entire back cover is loose.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver. Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards. Work your way around the phone until the entire back cover is loose and remove the mid-frame.
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  5. Using a spudger, pry the vibration motor connector from the motherboard.
    • Using a spudger, pry the vibration motor connector from the motherboard.
  6. Gently pry the vibration motor upwards using the spudger.
    • Gently pry the vibration motor upwards using the spudger.
    • The vibration motor is held down by some adhesive, force might be needed to remove it.
Заключение
Ryan
Участник с: 14.05.2012
223 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 8-4, Leahy Fall 2014 Member of USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 членов
Автор 5 руководств
Один комментарий
That is not the speaker, that is the motor for the vibrate functions...
The speaker is located in the plastic back of the housing near the camera hole.
tee1331 - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 1
За всё время: 1,212
