Введение
Here, the back cover will be removed followed by the secondary back panel. Once this is completed and the motherboard is visible, the vibration motor is accessible and can be replaced.
Выберете то, что вам нужно
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose and remove the mid-frame.
