ASUS Portable AiO PT2001 Heat Sink and Fan Replacement
Выберете то, что вам нужно
  1. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement, Back Panel: шаг 1, изображение 1 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement, Back Panel: шаг 1, изображение 2 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement, Back Panel: шаг 1, изображение 3 из 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 2, изображение 1 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 2, изображение 2 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 2, изображение 3 из 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 3, изображение 1 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 3, изображение 2 из 3 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 3, изображение 3 из 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement, Heat Sink and Fan: шаг 4, изображение 1 из 2 ASUS Portable AiO PT2001 Heat Sink and Fan Replacement, Heat Sink and Fan: шаг 4, изображение 2 из 2
    • Remove the tape attached to the heat sink and the metal enclosure.
    • Lift the metal enclosure off.
  5. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 5, изображение 1 из 1
    • Remove the four 3.0 mm Phillips #1 screws attaching the heat sink to the motherboard.
    • Remove the three 4.0 mm Phillips #1 screws connecting the fan to the device.
  6. ASUS Portable AiO PT2001 Heat Sink and Fan Replacement: шаг 6, изображение 1 из 1
    • Lift the heat sink and fan assembly off of the device.
    • When putting the heat sink back into place, reapply thermal paste to the underside of the heat sink where it rests on the motherboard.
Заключение
Elliot Kane
Участник с: 04/17/18
363 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G5, Livingston Spring 2018 Участник Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 353
