Введение
This guide will show you how to remove the wireless card in a few easy steps.
Выберете то, что вам нужно
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
Disconnect the three cables connecting the back panel ports to the motherboard.
Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
Gently wiggle the third connector out of its socket.
The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
Remove the 3.5 mm Phillips #1 screw from the wireless card.
Remove the connectors by pulling straight up on their ends.
Еще один человек закончил это руководство.
