Введение
A CPU Fan within a laptop is to help prevent overheating. If your laptop is experiencing overheating more than usual, or it happens every time you turn on your laptop there might be an issue or a broken CPU Fan. Follow these steps to replace a faulty CPU Fan.
Выберете то, что вам нужно
Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
Remove the six screws holding in the battery with a Phillips #0 screwdriver.
Once battery is lifted out and removed, proper dispose of the old battery.
Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
