Введение
Over time a laptop keys will be pushed a good amount, therefore it is no surprise that certain keys begin to stop working. Keyboard keys are easy to find on the market, and once a replacement key is bought follow these steps to replace that certain key.
  1. First, insert the opening tool, between the key cap and the hinge and push up gently. The key should pop out easily.
    • First, insert the opening tool, between the key cap and the hinge and push up gently.
    • The key should pop out easily.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Place, the flat head screwdriver between the two parts of the plastic hinge, and turn it a little so the first part pops out. You can start on either side, either the right or the left it does not matter, just make sure to do both sides.
    • Place, the flat head screwdriver between the two parts of the plastic hinge, and turn it a little so the first part pops out.
    • You can start on either side, either the right or the left it does not matter, just make sure to do both sides.
  4. Next remove the last plastic piece from the keyboard, and properly dispose of all three parts. Next remove the last plastic piece from the keyboard, and properly dispose of all three parts.
    • Next remove the last plastic piece from the keyboard, and properly dispose of all three parts.
Заключение
Scott Santiago
Участник с: 17.10.2017
526 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Member of UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
3 членов
Автор 5 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
За всё время: 205
