Введение
Sometimes a laptop will not turn on due to a broken or faulty power button PCB board. That means no information will be sent to the motherboard to turn on the laptop, however the board is also associated with the volume keys, therefore maybe it will turn on but the volume controls on the side will not work. If either of these things happen, follow this guide to replace the faulty power chip.
  1. Remove all 10 crews on the backplate using a Phillips #00 Screwdriver.
    • Remove all 10 crews on the backplate using a Phillips #00 Screwdriver.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. Carefully remove the backplate using the plastic opening tool. Carefully remove the backplate using the plastic opening tool.
    • Carefully remove the backplate using the plastic opening tool.
  3. Locate the battery near the bottom.
    • Locate the battery near the bottom.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Next, unplug the battery from the laptop in the upper left side of the battery, using tweezers.
    • Next, unplug the battery from the laptop in the upper left side of the battery, using tweezers.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  6. Remove the six screws holding in the battery with a Phillips #0 screwdriver. Once battery is lifted out and removed, proper dispose of the old battery.
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  7. Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  8. Locate the ribbon connector connecting the power chip to the mother board. Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily. Discard of the old power chip properly.
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
Заключение
Scott Santiago
Участник с: 17.10.2017
526 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Member of UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 3
За 30 дней: 20
За всё время: 428
