Введение
If the mouse isn’t properly tracking your movements, the trackpad may be faulty. Use this guide to replace the trackpad in your device.
Выберете то, что вам нужно
Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
Почти готово!
Заключение
