Введение
Keys can be dirty and unresponsive. Use this guide to clean under or replace keys.
Выберете то, что вам нужно
To remove a key, insert the opening tool in the small gap at the top right corner of the key.
Pry off the key by pulling the tool up until the key pops off.
If the key is still connected at the bottom, wiggle the key from side to side until it comes off.
To put the key back in, line it up with the area it came from and push it back in. There will be an audible click when it is correctly inserted.
Почти готово!
Финишная черта
